Grease won't pump into inner tie rod
Old 05-12-2010 | 10:07 PM
korygrandy's Avatar
Default Grease won't pump into inner tie rod
Well I replaced the inner tie rod without much trouble. I think I might have stripped the last thread that the inner tie-rod goes into where the grease fitting is as well. I went to pump grease into that grease fitting and it just wouldn't pump in. I replaced the fitting with a brand new one and still no luck. I can pump grease into the driver side inner tie rod with ease but not the case with the passenger side.
Are there any suggestions to fix this? Do I need to take the tie rod off and do something to grease this thing up?
Old 05-12-2010 | 10:10 PM
chrisbmo2000's Avatar
Check the grease gun and make sure its got grease.....lol
Old 05-13-2010 | 07:50 AM
korygrandy's Avatar
"I can pump grease into the driver side inner tie rod with ease but not the case with the pessenger side."
Old 05-13-2010 | 08:45 AM
sutehk's Avatar
Whrere I work, our machines have more grease zerks than Carter had pills. I encounter this alot, however, not sure this may help.
1. Check the recess in the tie rod end for obstructions. i.e. dried grease, dirt
2. The ball detents on brand new grease zerks like to stick sometimes. Try working the ball with something pointy.
Chris
Old 05-14-2010 | 11:49 PM
korygrandy's Avatar
I gave up on trying to pump grease into the tie-rod, took the rubber boot off and packed it the old fashioned way
chris7089
04-27-2013 01:34 PM
HighRigger
10-05-2008 11:33 AM
unclesam
05-14-2008 03:44 PM
iward05
15
11-05-2007 06:03 AM
Ol racer
10-31-2007 07:43 PM
Quick Reply: Grease won't pump into inner tie rod
