Hard to start when cold
My truck seems to be having an issue starting after it has sat and cooled off (mainly first start of the day). I have to give it some gas to get it to start ( like an old carb setup) and then hold it for a few seconds (10 -20) then it will idle, but not at a high choked idle. Its just a low, "im a cold-blooded witch", 300 rpm or so idle.
After it has had a chance to warm up, it will start normally for the rest of the day (unless it sits long enough to need choking)
Any ideas?
Any ideas?
RE: Hard to start when cold
how would i check for leaky injectors? to check the regulator ijust look for gas in the vacuum line right?
Isnt there something called a "cold start injector" or something like that? Do i even have one?
RE: Hard to start when cold ** UPDATED**
i have been google-ing my problem, alot of people have mentioned"02 senors""loose or corroded battery cables" and "I smell raw gas when it fires". Which I never really noticed a raw fuel smell since i usuall start my truck with the door closed, but after reading that I went out and tried it, and i do get a raw fuel smell.
SO, I decided to check my battery cables, low and behold they were loose. I dont know if the problem is corrected but ill find out tomorrow.
**************************** NEW QUESTION******************************
Can anyone tell me where the Blend door actuator is? Mine thumps everytime i turn the key on or off so i want to unplug it until i can get a new one.
a bad 02 sensor would throw a check engine, although if this only happens when its cold, during a cold start i do believe the comp looks at the coolent temp sensor, if the sensor is bad and not showing the right resistance when cold you will get a funky idle.
