Having transmission problems need help!!!
Old 03-04-2009 | 11:22 AM
joshua2236's Avatar
Default Having transmission problems need help!!!
I have a 1986 chevy c1500 silverado and I have two problems i am having trouble with and would like to ask for advice. My 350 turbo is leaking transmissioin fluid towards the front of the tranny closet to the motor and was wondering what it might be. Also my vents are not working. all of my air goes to the floor vent, nothing else works. if anyone can help i would appreciate it.
Old 03-04-2009 | 10:26 PM
chrisbmo2000's Avatar
front pump seal is why your tranny is leaking.....make sure when you get it changed you get it "staked" so it doesnt push out agian.....as far as vents go if I remember right the 86 was cable controled....pull out the control panel and check it out you may have a broken cable or airflow control door
02avalanche
10-17-2012 08:24 AM
Tim Compton
12-31-2011 08:40 AM
riderj46
01-16-2011 04:42 AM
Brandon Loschen
03-30-2009 11:06 AM
partsguy
09-25-2005 05:58 AM
Quick Reply: Having transmission problems need help!!!
