Header ?
Header ?
I just blew a header gasket over the weekend in the dunes. My truck sounds like a vw bug rite now which sucks. Im a pick up sum header gaskets today. With how many lbs of torque do I bolt the headers wit. They are heddman headers. Also I was thinkin of buying a throttle body spacer today and rite now i have no space between the fan shroud and the k&n intake. Will it be posible to cut the shroud to make the spacer fit or will it be to close to the fan.
RE: Header ?
i think fan shroud clearance is more of an individual problem (what intake/tbs you have) but you should be able to trim the shroud enough to fit it... i've never heard of somebody not being able to trim it enough...
if nothing else it could give you an excuse to go electric fans
RE: Header ?
Thanx for your replies. I put the the gasket and just did it tight and ill be checkin it after work for the next couple weeks. As for the spacer. I had to trim the k&n intake tube cuz the fan would hit it. I want to go wit electric fansbut that will have to wait.I bought the airaid tbs and it sounds great. I really cant feel the difference yet cuz I have my truck loaded. I have to wait till later today.
