Heater AC control assembly
1 Apply the parking brake to prevent the vehicle from moving.
2. If equipped with an automatic transmission, move the shift lever all the way down to last gear. Dont start vehicle just put key in run position.
3. Tilt the steering wheel to the full down position.
4. Pull gently rearward on the corners of the bezel from the instrument panel (IP) assembly.
5. Remove the bezel.
6. Unscrew the HVAC Module and Unplug.
