HELP. Brake lites on 99 Suburban.
Old 08-05-2007 | 08:44 PM
jim hughes's Avatar
Default HELP. Brake lites on 99 Suburban.
Hi, 99 Sub. blows fuse for the STOP lites when peddle is pressed. The flashers work fine until the fuse shorts out. Still blows after disconnecting the harness at the firewall. Even pulled the harness out from firewall back. RR switch under dash on the brake rode. Need to repair soon.What am I missing.
Thanks
Jim
Old 08-05-2007 | 09:00 PM
racethisz71's Avatar
Default RE: HELP. Brake lites on 99 Suburban.
did you check the brake light switch from the pedal or maybe the wires from the fuse box
Old 08-05-2007 | 09:16 PM
jim hughes's Avatar
I have changed the switch. Actual twice. Traced the wires to the fuse box all look very good. There has never been any trouble with this truck. All harness so far look brand new. I checked the front ABS harness also.
Old 08-05-2007 | 10:55 PM
get a wiring diragram and see what other objects are on the brake light circuit
Old 08-06-2007 | 05:50 AM
Argon's Avatar
maybe the turn signal switch...try unplugging that
redneckfamilyTBTTJJ
14
02-28-2012 12:19 PM
bikehauler
09-12-2011 12:27 PM
wug
10
09-23-2010 09:17 PM
knewbomb
10-11-2009 09:37 PM
SouthBayZ71
09-12-2007 08:32 PM
Quick Reply: HELP. Brake lites on 99 Suburban.
