Hey Argon
Old 07-23-2007 | 03:02 PM
BlackHorse99's Avatar
Default Hey Argon
Question for Argon
When removing the torque converter to flywheel bolts on the 99 silverado 5.3/4l60e is there a proper way, I have trouble holding the flywheel in place to pull against it, also the bolts are so incredibly tight i snapped to allen head sockets. Any ideas? How do they get er done in the real arena? Thanks ahead for the advice, bro.
Old 07-23-2007 | 04:56 PM
72charger's Avatar
Default RE: Hey Argon
I'm pretty sure your supposed to use air tools unless you have someone who can hold the crankshaft bolt with a big wrench to keep the engine from turning. But I would use an impact wrench.
Old 07-23-2007 | 04:58 PM
cant get one in there, belive me i tried...
Old 07-23-2007 | 05:44 PM
stopspazinout's Avatar
does the flywheel have large holes in it. when i did mine i had to jam a rod in it to hold the flywheel in place so i could get enough torque on the bolts an whalla they came loose.
Old 07-23-2007 | 07:16 PM
Argon's Avatar
take the little tin cover out of the bottom..its about as big around as a moon pie....have a helper hold the flywheel with a small prybar.
older 99's have an allen hole only (6mm,I think)...about 2000,they went to a 15mm shouldered bolt,still with the allen hole.
I use a breakover bar with a snap-on allen 6mm bit...its a pia,but I get em....parts has replacement bolts,that are shouldered for a 15 socket...MUCH easier
Old 07-23-2007 | 11:08 PM
Thanks man, looks like ill have to go to the tool store to gte oneseeing as i broke the last two, but ill give her a go, and definitely replace with a shouldered bolt, just curious, how much does a ring gear go for on one of these pickups, in case i have to fire up the torch?
Old 07-24-2007 | 05:12 AM
Argon's Avatar
****,I dunno..its a "flex-plate",to get technical...I bet its well over a 100 bucks...a used one should be plentiful though..if you have an indy trans shop nearby,they may sell ya one for just a few bucks
Old 07-24-2007 | 09:09 AM
thomas's Avatar
when i put in my converter in my 87 it was one of the easier things to take off. i just used a socket and a breaker bar
Old 07-24-2007 | 02:16 PM
Argon's Avatar
gmt 800's (99 and up) are different
Old 07-24-2007 | 05:08 PM
Well i got pissed and torched em, looks like im in the market for a flex plate...
