HVAC Question?
Old 07-15-2010 | 09:14 PM
ddixon72's Avatar
Default HVAC Question?
Hey new to this site just a couple of quick questions. I have a 04 silverado crew cab Z71 w/ 5.3 and i still get a fair amount of air blowing through the vents even with the blower off there is also a thump and then hissing noise comming from the dash not sure if thare are related.
Old 07-15-2010 | 09:30 PM
chevy112488's Avatar
is it a repeated thump? sounds like your fresh air door could be out of sync. if thats the problem, it could possibly be fixed with a reprogram, unless the actuator has gone bad, in which case you'll need to replace it.
Old 07-15-2010 | 09:36 PM
ddixon72's Avatar
it will thump and hiss and about 5-10 seconds later it will thump and then hiss and keep doing this till i shut it off.
Old 07-15-2010 | 09:48 PM
yeah sounds like you need a trip to the dealer for a reflash.
Old 07-15-2010 | 09:57 PM
ddixon72's Avatar
thanks got a couple other issues for them to look at, thanks again.
Old 07-15-2010 | 11:47 PM
timber74wolf's Avatar
You will have air coming through the vents even with the blower motor turned off as far as I know. Every GM truck I have been in is like that.
jerry101
06-20-2011 07:49 PM
yelladog
07-02-2009 08:49 AM
impac41
06-03-2009 07:23 PM
reuse2recycle
07-09-2008 10:42 PM
snafu
11-28-2005 11:07 PM
Quick Reply: HVAC Question?
