I need to change light bulb behind headlight switch
RE: I need to change light bulb behind headlight switch
My truck you need to adjust the steering all they way down, then pull the shifter all the way down, then pull the corners of the dash gently, then the rest will follow. Then you have to work it out from around the steering cloumn, but its not as bad as it sounds.
The entire thing should pull out as one piece and the bulbs are accessable on the board. FYI sometimes cleaning the contacts is all the bulbs need to work. Those suckers can be expensive!
Piper316
08-08-2011 03:26 AM
GMCSierraFan
04-10-2010 06:25 PM
