IAC valve
RE: IAC valve
What symptoms do you have that make you think your IAC is going south? It seems to me that one of the simplest tests to verify that the IAC is working is tolook at the idle speed, then turn on various accessories such as the A/C, etc. and verify that the idle speed is maintained. Putting the vehicle in gear and verifying that idle speed is maintained should be the final test I would think.
This link isn't particular to your vehicle, and probably isn't a thorough way of testing, but definitely can help get you started in the right direction.
Testing IAC valve on 1988-98 Silverado
Do you have the Factory Service Manual? I'd imagine it would go over the testing or diagnosis in aspecific manner. Of course, if they tell you to use the diagnostic scan tool, then it's not too much help.
