Idle problem
Old 12-11-2007 | 01:42 PM
sledhead151's Avatar
Default Idle problem
more about the idle problem: It idles up to about 1700rpm then drops to around 500 almost stalling i have to keep a little gas on or it will stall when it drops to 500
Old 12-11-2007 | 01:59 PM
Argon's Avatar
Default RE: Idle problem
what year?
Old 12-11-2007 | 02:32 PM
2000 chevy silverado 5.3L
Old 12-11-2007 | 04:36 PM
BigRandy95's Avatar
nevermind didnt read your other post
Old 12-11-2007 | 10:12 PM
Cracker's Avatar
Have you made any modifications to the intake recently? Or had any work done to it?
Old 12-12-2007 | 01:56 AM
72charger's Avatar
bad tps???
Old 12-12-2007 | 05:27 PM
no mods done, its completly stock
Old 12-12-2007 | 10:18 PM
Cracker's Avatar
I wonder if a knock sensor would have that effect. Is it possible to leave it at a dealer overnight so they can check for codes on start up?
Old 12-13-2007 | 12:44 AM
stopspazinout's Avatar
mine did the same thing when my idle control valve went out a couple monthes ago. is that 2000 a distributorless system?
Old 12-13-2007 | 07:51 PM
Cracker's Avatar
Yes, the 2000s use seperate coil packs.
