Instrument Panel Lights Not Working
Old 04-27-2009 | 11:22 PM
CrazyTexan's Avatar
Default Instrument Panel Lights Not Working
I have a 99 Silverado and after messing with some things in the dash (radio/ac switches) the lights that illuminate the speedometer, ac switches, and headlights no longer come on. Any ideas as to what may be causing this would be appreciated...
This is not my truck but these are the lights that are not working. The low fuel, check engine, abs lights, etc work.
Old 04-27-2009 | 11:50 PM
EvansBlue's Avatar
You need to look for a fuse marked "ILLUM", "DSHILLUM", or "STRILLUM". Also could be under "GAUGES". Also, check your Backup and parking lamp fuse.
Old 04-28-2009 | 12:17 AM
CrazyTexan's Avatar
I checked them and none of them were blown.
Old 04-28-2009 | 07:15 AM
Check your dimmer switch.
Old 04-28-2009 | 10:03 AM
CrazyTexan's Avatar
Apparently for some reason the dimmer wheel other than set in the on position decided to stop working randomly. I swapped it out with another trucks switch and it works like it should. Its just weird how all the sudden it decided to quit working.
dimmuborgir6nik6
21
05-12-2023 04:58 PM
sddmr7
04-10-2011 01:57 PM
bcraig24
08-02-2010 01:46 AM
jstill
12-12-2008 03:31 PM
97markviii
01-05-2008 08:10 PM
Quick Reply: Instrument Panel Lights Not Working
