Intake TBS question - please help
Old 01-07-2008 | 07:46 PM
pweiss's Avatar
Default Intake TBS question - please help
Hey Everyone,
I have been looking for an answer for this question for a few days now but I can't find one.
I just installed my K&N intake on my 05 sierra 5.3. Evidently you can't use a TBS without making modifications for my make and model. Is this true? I contacted K&N and they don't recommend using a TBS because of the modifications which will void the warranty (which I'm not worried about). Has anyone put a TBS on with a K&N intake? Do you need to do any modifications? Which TBS did you use? And finally, how important is using the stripping around the intake guard?
Thanks for your help!!
Old 01-07-2008 | 08:37 PM
smoke20's Avatar
Default RE: Intake TBS question - please help
I am not sure about the K&N, but I have the volant and the tbs and no modification was needed. I assume the K&N is pretty close in design. You should be fine especially with all the room the 05' has with the electric fans. I have the transdapt. And finally, I am not sure what you are talking about with the "striping around the itake guard".
Old 01-07-2008 | 11:16 PM
Cvtsax's Avatar
Pweiss, its a gasket that goes around the heat shield I guess for added protection for when you close the hood to fill the space, anyways I have one too and to install the gasket cut it at the corners of the shield so it will bend (otherwise it wont) With a little patience and work you can get it to fit
Old 01-08-2008 | 09:28 AM
72charger's Avatar
^Definately patience!^
Old 01-08-2008 | 11:45 AM
04BLKCHEVY's Avatar
I have the 6.0 and had to actually cut the intake tube when i put the tbs. I was going to cut the shroud but then measured a lil more and saw that with that extra inch or so wit the tbs the tube would hit the fan. I cut the tube and works fine.
Old 01-08-2008 | 11:59 AM
pweiss's Avatar
Did you notice any difference in performance when you installed teh TBS?
Does
Old 01-08-2008 | 12:03 PM
pweiss's Avatar
Does anyone know if the 05 has more room between the fan than the 04? I don't want to cut the tube if i don't have to.
Is having the spacer even worth it?
Old 01-08-2008 | 02:33 PM
04BLKCHEVY's Avatar
It was worth it for me. Does feel better and i have noticed a difference in my gas mileage.
Old 01-08-2008 | 07:53 PM
pweiss's Avatar
How long did it take to install with the tube modifications? Did you use a simple hack saw?
Old 01-09-2008 | 12:47 AM
Cvtsax's Avatar
So, what TBS is the best with my truck (00 5.3) with a K&N 77 intake. I would rather not trim the intake or fan shroud but will I guess if need be. Anyways, most everyone has been good with the trans dapt so I was looking at those. Any input from same year and engine that have done would be awesome. Thanks
popo
16
02-28-2008 11:08 PM
6mins2live
02-24-2008 12:07 PM
martyn
02-03-2008 04:49 PM
superddd
16
04-19-2007 12:21 PM
hunt4game29
24
04-11-2007 12:18 PM
