key cylinder remover
Old 02-28-2008 | 04:05 AM
ob22005's Avatar
Default key cylinder remover
what's the procedure of removing the key cylinder from a c1500 gmc truck. can anyone tell me.
Old 02-28-2008 | 08:25 AM
Argon's Avatar
Default RE: key cylinder remover
what year?
Old 03-03-2008 | 03:34 PM
ob22005's Avatar
Sorry About That. It's A 1989
Old 03-03-2008 | 03:59 PM
Argon's Avatar
89isprettysmple,but you'll need a couple of special tools....a steering wheel puller,and lock-ring depressor...the key cylinder is pretty cheap with 2 new keys...
Old 03-03-2008 | 06:02 PM
ob22005's Avatar
I've removed everything down to cylinder but it won't come out, the key is stuck in the run position.
Old 03-03-2008 | 06:19 PM
Argon's Avatar
did ya take that torx bolt out???
Old 03-03-2008 | 09:40 PM
ob22005's Avatar
Didn't Know About A Torx Screw. Where Is It Located??
Old 03-03-2008 | 09:46 PM
ob22005's Avatar
There Is a Bolt Just Above The Cylinder, Not A Torx, And It Just Turn But Won't Come Out.
Old 03-04-2008 | 04:22 AM
Argon's Avatar
yeah..under the turn signal switch...then there is a plastic/metal key buzzer spring to take out of a hole...then it should be a torx...unless someone switched it
cowboyboose
10-06-2010 07:10 PM
piton
05-13-2008 08:00 AM
rustyfan
02-17-2008 04:33 PM
superddd
06-12-2007 10:33 PM
discoinferno65
10-12-2006 05:52 AM
