Key removal
Old 03-07-2011 | 07:43 PM
bikernut's Avatar
Default Key removal
I just purchased a 2003 GMC 3500 4x4 dump truck. when I shut it off I can't remove the key from the ignition switch without pushing the shift lever up a bit. It seems like the spring that holds the shift lever up it loose or maybe there is an adjustment to it to keep the lever up in position, it only has to move about a 1/2" up and the key comes out. Is this something that has an adjustment or does something need to be replaced. In either case can you give instructions or is this better off at the dealership? Thanks
1navyguy
06-20-2008 05:15 PM
Derekm162
09-23-2007 08:55 PM
bosco269
08-16-2006 11:30 PM
bosco269
08-10-2006 01:25 PM
rebecca1
07-07-2006 08:22 PM
Quick Reply: Key removal
