Keyless entry
Old 01-20-2012 | 08:59 PM
JOHNNYBUILT's Avatar
Default Keyless entry
New here, just joined.
Just bought an 01 chevy silverado 2500hd crew with the duramax.
First off love the truck, but it's got some issues.
The keyless entry doesn't work. It doesn't lock or unlock, but the panic button does work. Have to open the doors with the key. The power lock buttons on both door panels work fine. Has me stumped. Does anyone have any ideas or solutions. Any help would be greatly appreciated.
Old 01-21-2012 | 03:00 AM
RUFFNECK4LYFE's Avatar
May need to get the remote(s) reprogrammed. The dealer can do it for ya, but I have seen how some can do it yourself. Let me try to find that for ya to save a few bucks.
Old 01-21-2012 | 07:05 AM
acnas's Avatar
IMPORTANT: All transmitters which are to be recognized by the Remote Control Door Lock Receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed.Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.You may program up to 4 transmitters, using either of the two following procedures: Transmitter Programming Procedure (Method 1 - No Tools Required) 1. Close all the vehicle doors. 2. Insert the ignition key into the ignition lock cylinder. 3. Press and hold the door unlock switch. 4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF. 5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode. 6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter. 7. Repeat the previous step to program up to four transmitters. 8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode. 9. Operate the transmitter functions in order to verify correct system operation. Transmitter Programming Procedure (Method 2 - Scan Tool Required) 1. Install a scan tool. 2. Turn the ignition ON, with the engine OFF. 3. Use the scan tool in order to access the Body Control Module (BCM) Special Function: Program Key Fobs menu. 4. Follow the directions on the scan tool in order to program the transmitters. 5. Operate the transmitter functions in order to verify correct system operation.
Old 01-21-2012 | 12:28 PM
Thanks, i'll go out and give it a try now
Old 01-22-2012 | 01:25 PM
Thanks for the help the door remotes all work now. Now for the power mirrors and the pesky abs+brake lite issue. But thats for another thread.
Thanks again guys
chevytillidie24
08-16-2007 04:44 AM
onejediknight
07-31-2007 09:38 AM
bph
07-20-2007 04:18 AM
Godti
06-13-2007 07:35 PM
mca17
10-22-2006 03:06 PM
Quick Reply: Keyless entry
