Knock sensor
Old 06-12-2012 | 05:10 PM
scott_z71's Avatar
I Thanks for all of the info. Are both knock sensors the same? I seen a dual wire and a single wire when looking up parts. I seen one of the post talking about using RTV on the knock sensors. Is that to put on the threads or put around know sensor to seal it after it is installed? I'm planning on replacing them this weekend. I also noticed that there are a few different intake manifold gaskets and kits. Any tips on a good one or one to avoid? 2006 with 5.3
  #12
Old 06-12-2012 | 05:29 PM
scott_z71's Avatar
My truck is a 2006 with 5.3L
  #13
Old 06-12-2012 | 06:11 PM
acnas's Avatar
I would use all GM parts. Harness and sensors and intake gasket kit. All I ever used. Nothing on sensor threads. Torque sensors 15 lb ft. No more No less. Use rtv on the rubber plugs to seal out water. Intake tighten the bolts a first pass in sequence to 5 N·m (44 lb in). Tighten the bolts a final pass in sequence to 10 N·m (89 lb in). Start in the middle work your way to front to back crisscross left to right.
Lifted4Christ2005
16
08-02-2010 09:55 PM
morganautoservice
05-14-2010 12:18 PM
TiltRotor
03-01-2009 06:36 PM
chevy112488
11
03-28-2008 12:06 AM
superddd
07-27-2007 03:09 PM
