leak at water pump
Old 12-06-2007 | 07:58 PM
deadwood144's Avatar
Default leak at water pump
I have a '03 stepside, 4.8L (64k miles) that's losing coolant. There is some discoloration where the water pump meets the engine block. Any guidance here about where to start? Thanks.
[align=left] [/align]
Old 12-06-2007 | 08:01 PM
Cracker's Avatar
Default RE: leak at water pump
The weep holes are warning signs that your pump is failing, and also causing the discoloration. Change the water pump and the T-stat at the same time.
Old 12-06-2007 | 08:02 PM
smoke20's Avatar
Once again cracker is right, pump time.
Old 12-06-2007 | 08:03 PM
Cracker's Avatar
Hah...who says alcohol clouds your judgement.
Old 12-06-2007 | 08:10 PM
Smoke/Cracker,
Are these weep holes/ indicaters at the area where the pump mounts to the engine? Sorry to be a blockhead, but failues of water pumps on past trucks were different.
Old 12-06-2007 | 08:14 PM
racethisz71's Avatar
mine was leaking from the constant tension clamp that connects the raditor hose to the waterpump
Old 12-06-2007 | 08:22 PM
Cracker's Avatar
The weep hole is below the line of sight when looking at the top of the engine. I assumed your view was from that vantage. The coolant will follow the "arms" of the pump to the block and leave a residue of rust and debris that naturally occures in the coolant system.
Old 12-06-2007 | 08:43 PM
Thanks for your help. Should the timing belt be changed at this point while the pump is off?
Old 12-06-2007 | 10:10 PM
smoke20's Avatar
Only if there is an issue. How many miles on yours?
Old 12-07-2007 | 04:32 AM
Argon's Avatar
Timing belt?..i'm not even as drunk as cracker tonite,and I know there is no timing belt...just a drive belt....
price a gm pump...comes with a thermostat as well,and you won't have to change it again next month
In2Trux
04-19-2015 08:50 PM
98fordf154.2
05-31-2011 05:42 PM
kingofboulder
07-31-2010 07:32 AM
silverado99_1
06-04-2008 04:09 AM
KS Z71
01-27-2006 04:19 AM
Quick Reply: leak at water pump
