Leaking Coolant After Shutting Off
I have a 2000 Chevy 2500 4x4 5.7l. It is the work truck version so it is the 88-98 body style. It has 71k miles on it.
The truck is leaking coolant aftet and only after i shut it off. it doesnt leak or overheat while driving, as long as there is coolant in it. It is leaking out the side of the water pump from a small hole. I would say it is the seep hole but it looks like the seep hole is on top of the water pump.
I suggest changing sooner than later, this is my non-professional opinion and is worth exactly what I'm being paid for it, LOL.
A seal protects the water pump impeller shaft bearing from contamination by engine coolant. If this seal fails, the weep hole in the pump snout will leak coolant. If this is the case, shaft bearing failure will follow. You should probably replace the water pump as soon as possible. But like above stated, this info is worth what I am getting paid also! Happy hunting! Also, is there a high pitched squealing sound from your belt or water pump during operation? This could also indicate failure.
Did you take the belt off? If so put it back on. Have a friend hold the belt tight and hit the wrench in the opposite direction the fan spins. It will not look like it is loosening, but when it does you will know it.
I only had myself so i ended up tie strapping the pulley to the fender well with some rubber hose over the strap. couple of hits with the dead blow and it loosened right up! Then I had a problem keeping the gaskets in place while trying to get the water pump in. Eventually the silicone dried up and i had to get new gaskets. and a can of spray glue. A buddy of mine is a heavy equip. mech. spray glue the gaskets to the water pump with silicone on the block. Worked perfect!
