LED Turn Signals
Old 02-22-2010 | 06:50 PM
Downhand Dan's Avatar
Default LED Turn Signals
I have a 2008 3500 GMC Sierra that I have converted to LED lights. Now my turn signals blink at a rapid pace, I need to correct this problem. I am having trouble getting an answer on how to go about it. If anyone has an answer I would appreciate your input.
Thanx...
Old 05-20-2010 | 03:44 AM
Mad Max's Avatar
This is a common problem for people with LED lights. Since LED's have a lower resistance, it causes them to blink faster. Best fix is to wire your taillights in a parallel circuit, which requires using a resistor. There are plenty of help sites that can show you exactly how to do it. Hope this helps.
Old 05-20-2010 | 08:36 AM
RUFFNECK4LYFE's Avatar
They sell flashers made for LED to fix that. Either that or resistors.
Old 05-21-2010 | 12:22 PM
tasutt2009's Avatar
simply replace the OEM flasher unit(s) with an HD (heavy duty). The heavyer windings on the coil provide enough resistance.
geekgame818
07-11-2012 04:41 AM
Downhand Dan
02-24-2010 04:42 PM
Lovemydiesel
01-24-2009 07:07 AM
daryl
09-10-2008 04:32 AM
bobbie53
06-01-2007 01:25 PM
Quick Reply: LED Turn Signals
