Leveling Question
Old 07-09-2010 | 07:28 PM
parbalicious's Avatar
Default Leveling Question
Hi all! New to the forum. I have a 2010 Silverado 1500 Crew Cab z71 4x4 and would like to level the front...have seen posts about 2 inch and 2.5 inch leveling kits. which one would level the truck? Also, the stock tires are 265 65 18's. I would like to go to a bigger tire and keep the z71 wheels. Saw a similar truck that had 305 65 18's. Does anyone know if there would be a rubbing issue or any other issue with a leveling kit? Thanks in advance.
Old 09-02-2010 | 01:06 AM
Travis West's Avatar
Member
i have a buddy that has thirty fives on a stock z71 with the torsion bars up, they scrub a little but i will let u no the exact size here in a little bit if u want, the tires arent big enough in less there is a little scrubb haha
Old 09-02-2010 | 01:08 AM
Member
and if ur readin this, is there any way i could level out a 05 sierra without messin with the torsion bars more than i have
Old 09-02-2010 | 04:56 PM
firefighter148's Avatar
i just bought a 2010 silverado and have 285's on it and it has a 2.5 leveling kit. i could easily go bigger on the tire but thats just wat was on old truck. good luck
Old 09-03-2010 | 01:42 AM
02camarossle's Avatar
Member
the 2010's dont have torsion bars they are coil overs... and if you do a 2.5" spacer in the front then you can easily fit a 305 65 18 tire, i have seen one at work before and im not sure if he even lifted it, my friend at work has a 2008 sierra 4x4 woth 35 1250 20's and his still rubs a little bit when you turn the wheel all the way... if you want a bad *** all terrain that is quite and does amazing off road get the bfg all terrain, you will love them i promise you!
Old 09-07-2010 | 12:46 AM
Member
they arent quite big enough if there isnt a little scrubb haha but i just feel like it settles back down on the front when i tightin the torsion bars
Andrew71
05-06-2009 04:43 PM
bigdaddyred
11
12-02-2007 10:41 PM
Norseman
10
11-08-2007 01:40 PM
01GrEeNmAcHiNe
08-27-2006 12:56 PM
bro1972
02-23-2006 05:51 PM
Quick Reply: Leveling Question
