Loud squeel when fan or AC turned on
Old 10-04-2011 | 06:08 PM
Wile e.1.'s Avatar
Default Loud squeel when fan or AC turned on
Have an 02 Sierra 5.3 Z71, 30 k miles. When I put the air or heat on , there is a couple second loud sqeel under the hood, goes away then does it again. After a few times it happens less and less and will go away while driving. I changed out the serpentine belt ( the original ) no change. I guess it is a pully or bearing ??? Anyone have experience with this, Oh yeah...sometimes happens when starting. Very annoying, but as you can see , the truck is not driven too often. Any help appreciated. Thank you
Old 10-04-2011 | 07:17 PM
acnas's Avatar
Did you change the main belt or the ac belt? Possible ac belt and or ac belt tensioner? Seen the ac belt tensioner seize.
Old 10-04-2011 | 08:29 PM
Wile e.1.'s Avatar
I changed the serpentine belt, and the tensioner seems ok...tension is good, spins fine. ( is there 2 belts on a 02 sierra, thought there was only 1 main belt ) Both the AC and the heat work well, its just the initial squeel from under the hood when the fan motor is turned on, I did not think the belt would fix it...its more of a metal on metal noise than a belt squeel. kinda like a bad bearing ..the noise will come and go for lets say about 15 minutes of driving ,only for short durations, then I wont hear it anymore till the next trip
Old 10-04-2011 | 08:49 PM
Yes there are 2 belts - change the A/C belt.
Old 10-05-2011 | 12:40 PM
Wile e.1.'s Avatar
thanks for the replys, found a u tube video for changing the ac tensioner and belt, so looks like I got a saturday project. Thankfully not a pricey or difficult lookin job. thanks again for your time
Old 10-05-2011 | 07:02 PM
Wile e.1.'s Avatar
turned out to be the a/c tensioner, replaced it and put on a new belt also, truck sounds great again. thanks for the info.
Old 10-05-2011 | 10:28 PM
Cool glad you got it fixed and thanks for posting your results!
silveradomike01583
03-27-2011 02:24 PM
Mr_Shamrock
8
07-26-2010 02:50 PM
Mr_Shamrock
9
07-06-2009 03:40 PM
78chev2bnice
02-28-2008 09:45 AM
gmight
07-27-2006 12:24 PM
