MAF cleaner
Old 02-04-2008 | 01:50 PM
bad2006z71's Avatar
Default MAF cleaner
hey guys what do i use to clean my Mass Air Flow sensor?
can you just use carb cleaner?
do you just spray it then let it dry or is there something else you have to do?
thanks
Old 02-04-2008 | 01:52 PM
jcbst12's Avatar
Default RE: MAF cleaner
They make MAF cleaner, either that or eletromotive or Throttle Body cleaner.
Old 02-04-2008 | 02:16 PM
stopspazinout's Avatar
get either the specific maf cleaner or some electromotive cleaner those will clean it without causing any damage.
Old 02-04-2008 | 02:18 PM
bad2006z71's Avatar
so can i just go to autozone and ask for maf cleaner or is there a specific brand you guys are using?
thanks
Old 02-04-2008 | 03:20 PM
jcbst12's Avatar
Pretty much. CRC makes the stuff I use. I got it at Advance Auto.
Old 02-04-2008 | 05:56 PM
donkeydan's Avatar
does it really work?
Old 02-04-2008 | 08:31 PM
rxsteven's Avatar
Do you remember how much? Ive been using Brake Clean and a clean rag.
Old 02-04-2008 | 08:33 PM
DamnYankee's Avatar
It's on the shelf - just any MAF cleaner will work.
Old 02-05-2008 | 08:51 AM
jcbst12's Avatar
I can't remember how much it was. I assume about as much as good TB cleaner would be. Yes it works. I spray it out and by the time I put it all back together its dry and ready to go. DamnYankee is right, any MAF cleaner will work.
Old 02-05-2008 | 09:29 AM
bad2006z71's Avatar
looks like this is at Advanced auto
CRC Chemicals Mass Air Flow Sensor Cleaner: 11 Wt Oz
