Maintenance question?
Old 10-30-2007 | 08:23 AM
mysilvy's Avatar
Default Maintenance question?
sometimes i get a clunking noise when i put the tranny in rev. does any one know what is the problem and how i can remedy this?
can anybody tell me the lube points on the chassis and anywhere else that needs grease.
clanking noise like metal to metal from the rear susp. worn leaf springs maybe?
any body know where to get transfer case fluid besides 30 dollars a qt from the dealer? Thanks in advance.
Old 10-30-2007 | 11:18 AM
Argon's Avatar
Default RE: Maintenance question?
make sure you get the CORRECT fluid if your thrifty shopping for it....10 bucks saved is not much when ya burn up a 2000$ transfer case.
Old 10-30-2007 | 11:41 AM
jcbst12's Avatar
Just use the factory fluid. Anything else will spell out certain doom for your transfer case. Buy the fluid, add it, and if it still clunks there are some other things you can try. There are 9 or 10 grease (zerk) fittings up front and possibly one on the rear drive shaft and one on the front drive shaft. There is at least 9 on the trucks front suspension.
Old 10-31-2007 | 04:01 PM
airmech_1's Avatar
I bought the dealer fluid auto-tracII $6 qt takes about 3 qts. I have the NP8 trans case. I could not find anything like that in any store. Good luck
ford_guy
09-22-2012 06:39 AM
DMatthews
02-28-2011 12:42 PM
Mr_Shamrock
07-28-2009 09:59 PM
Nordric
08-02-2007 03:38 PM
CrimsonSam
08-07-2006 12:43 PM
