MAP Sensor question
Old 07-06-2011 | 05:36 PM
webb0844's Avatar
Default MAP Sensor question
have a 92 Chevy c1500 tbi with idleing issues, i've replaced fuel filter, fuel pressure is good as well as injectors, fuel pressure reg, plugs and harness, EGR and MAP Sensor. All the voltage checks are good on the MAP sensor, however when i disconnect the wiring connector from the map the truck idles fine, reconnect the wiring connector and it stalls out. this is the 2nd map sensor i've tested both with the same results..any thoughts?
Old 07-06-2011 | 05:48 PM
Wiked's Avatar
Do you mean MAF? (mass air flow sensor)
and when you replaced it did you touch that thin wire? any foreign matter that gets on that can make that thing not work properly
Old 07-06-2011 | 07:17 PM
TBI trucks don't have mass air flow sensors.
Old 07-06-2011 | 08:18 PM
cubpak89's Avatar
they have a map or manifold absolute pressure sensor to be technical
Old 07-07-2011 | 05:06 AM
Wiked's Avatar
I stand corrected.
Old 07-07-2011 | 11:19 AM
webb0844's Avatar
Thats correct manifold absolute pressure sensor.
Old 07-07-2011 | 06:08 PM
RUFFNECK4LYFE's Avatar
A bad temp sensor can also cause this.
Old 07-08-2011 | 07:35 AM
webb0844's Avatar
so you're suggesting replacing temp sensors to fix the map sensor problem? i know there has to be an underlying problem somewhere down the line of the map sensor, i'm just at a loss as to where else to look.
woodyboy
11-17-2011 08:45 AM
pop
09-25-2011 09:55 PM
sparker7062
07-11-2010 09:38 AM
brooke01
01-04-2007 08:43 PM
LarryMc
12-10-2006 01:56 AM
Quick Reply: MAP Sensor question
