Mass Air Flow Sensor v6
Old 07-19-2010 | 06:03 PM
mrhippo's Avatar
Default Mass Air Flow Sensor v6
I'm looking to replace the Mass Air Flow sensor on my 04 Silverado V6. I would like to pick up the part for as little cost as possible. Is the mass air flow sensor different between v8 and v6 models? Any suggestions? Thank you in advance!
Old 07-20-2010 | 01:20 AM
RUFFNECK4LYFE's Avatar
Yes they have different settings. Just get one remanufactured from the parts store and should be good to go. Do you have a different air filter or set up?
Old 07-20-2010 | 09:13 PM
mrhippo's Avatar
thanks for the reply. and nope, its all stock, but should I also change the air filter (or only if needed) when doing the sensor?
Old 07-21-2010 | 02:15 AM
Well I was making sure u didnt have a aftermarket oiled filter like K&N. They dirty up the sensor and will throw the readings a little off. A clean new paper filter will do you just fine. I would change it every oil change to get maximum performance and MPG's.
03chevy2
06-19-2013 10:54 PM
huntin03z71
12-27-2009 10:53 PM
jester
05-07-2008 11:07 PM
mikystyle
02-07-2006 02:58 AM
03ftby
10-08-2005 04:24 PM
