MSD 8.5mm wires ???????
Old 04-03-2007 | 08:59 PM
gas guzzlin 4x4's Avatar
Default MSD 8.5mm wires ???????
Recently swapped out my stock plug wires for MSD 8.5mm wires with all other stock components in place. Now the idle is rough, but the truck still has plenty of power. oh yeah 2000 Sliverado 4x4 Vortec 4.3 automatic. Any replies welcome.Should have I stuck with the factory 7mm wires?
Thanks for all of your help, thanks to the good people on this site I have eliminated many problems with my truck. I will work on this thing until I die before I would buy a foreign rice burnin piece of ****.
Please Help.[8D]
Old 04-03-2007 | 10:20 PM
smoke20's Avatar
Default RE: MSD 8.5mm wires ???????
If all your connections are good, then you may have a bad wire. If it idled well before, try using one of your old wires and replace one wire at a time with the old wire till you find if one is bad. I can't imagine going to a bigger wire would make it idle rough.
Old 04-03-2007 | 11:08 PM
SC_Chevy_Lover's Avatar
I agree with smoke! In most cases, increasing the diameter will smooth out a rough idle, not make it worse. Check all of your connections, then go from there. Good luck!
legacy
11-12-2007 08:20 AM
stopspazinout
07-24-2007 04:08 AM
chev.half
11
06-14-2007 10:51 AM
SC_Chevy_Lover
05-06-2007 10:36 PM
wellbu
08-02-2006 08:34 PM
Quick Reply: MSD 8.5mm wires ???????
