mufflers
mufflers
Does anybody know the difference between the flowmaster mufflers? I am planing on flowmaster 40 delta, but if 50 series or other are better then I will change. I just cannot find a good source to tell if any are better performance wise or just lower sound in cab. Even from flomaster site.
RE: mufflers
SMOKE,
THE 40 SERIES IS AN ALL OUT PERFORMANCE FLOW AND SOUND MUFFLER.I AM PRETTY SURE THE 50 IS THE FORCE 2 SYSTEM. MUCH QUITER, AND I THINK ITS A WASTE OF TIME. THE 70 SERIES ARE TYPICALLY USED ON RV APPLICATIONS. THE DELTA AND THE SUPER 40 ARE SIMILAR. I AM PRETTY SURE THE DELTA IS ALSO USED WHERE SPACE IS A FACTOR I WOULD STICK WITH THE SUPER 40. HOPR I HELPED
RE: mufflers
Gearheadrt - do you think the super 40 are that much better than the delta 40? I want the most power I can get, but don't want the cab resonance. The headers are loud enough at full power. I used to like the loudness when I was younger but now I want good sound without the volume at cruising speeds. I don't mind when I floor it though, it can be as loud as needed then.
RE: mufflers
SMOKE,
THATS THE THING, MY SUPER 40 IS LOUD INSIDE, BUT I LIKE IT. I ALSO HAVE SIDE EXIT, ( NASCAR TRUCKS ) MY BUDDY HAS THE FORCE 2 AND YOU REALLY DONT HEAR IT UNLESS YOU GET ON IT. I AM GONNA TRY TO PUT A SOUND CLIP ON HERE OF THE 40'S SOUND AROUND 70MPH OR SO. BUT YOU DEFINITLY HEAR THEM INDIDE THE CAB. HOPE THIS HELPED
RE: mufflers
Thanks guys, I wil probably stick with the 40 Deltas like I had on my last truck. They were loud on acceleration, but quite on cruise in the cab and still sounded powerful outside. Nothing like a good sounding exhaust.
