My Hemi Killer won't come alive
Old 06-21-2007 | 08:15 PM
likearock's Avatar
Default My Hemi Killer won't come alive
I put a beefed up383 strokerand 350 turbotransmission in my 92 silverado and had it turning over trying to set the timing when it just stopped turning the motor over im frightened that I locked it up but the motor was ran once to be dynoedand ran fine and the motor didn't even fire when i was trying to set the timing can any one help me outI would be very thankful.
Old 06-21-2007 | 08:20 PM
smoke20's Avatar
Default RE: My Hemi Killer won't come alive
sounds electrical. check your fuses and ground, starter, starter relay, etc. Do you have any electrical power?
Old 06-21-2007 | 09:39 PM
likearock's Avatar
Yeah it has power, the starter engages but doesn't turn it over but I have more than enough power from the battery.
Old 06-21-2007 | 10:56 PM
stopspazinout's Avatar
are you sure its engaging? and not spinning without engaging? pull the starter and test it to see if when its hit it spins and actuates.
Old 06-22-2007 | 04:47 PM
likearock's Avatar
Yeah you hear the starter engage and it just doesn't turn it over I was told to barr it over myself and im going to try that to see if I cant bust it loose or find out what is ceased.
Old 06-22-2007 | 10:01 PM
smoke20's Avatar
also make sure the teeth on the ring gear are not worn off, maybe you hada misalignment issue and damaged it.
SgtSmithProductions
Ford How-To's and Tutorials
01-17-2011 08:45 AM
Gloveberg
12-21-2010 10:35 AM
EvansBlue
06-13-2008 04:10 PM
74orangedart
11-29-2007 08:53 PM
tomdunn420
05-18-2006 06:29 PM
