Mystery Switch
Old 07-09-2008 | 08:48 PM
FlyingChipmunk's Avatar
Default Mystery Switch
I found this toggle switch under the steering column anyone know what it does. I checked the manual but no luck. I will take a pic in the morning if it helps.
Old 07-09-2008 | 08:52 PM
rxsteven's Avatar
Default RE: Mystery Switch
Might be a kill switch you dont have two gas tanks do you?
Old 07-09-2008 | 08:57 PM
EarnhardtZ71's Avatar
Steering wheel adjustment?
j/k I have no idea
Old 07-09-2008 | 09:13 PM
Old 07-09-2008 | 09:15 PM
sorry its huge but there it is..
Old 07-09-2008 | 09:27 PM
rxsteven's Avatar
Looks like a kill switch hit and try to start your truck. It might start and run for a few and then die. I had a 85 Firebird with one and I would leave it on all the time. Id get a block away and it would die.
Old 07-10-2008 | 09:41 AM
gpet6669's Avatar
Does your truck have a security system or a remote starter? Anything aftermarket under the dash or with wiring? Check your exhuast and see if there is somthing cool like a cut-out!
Old 07-10-2008 | 10:25 AM
charlyg's Avatar
Car alarm switch. I bought used and have all the wires and plugs from a previous alarm system.
Old 07-10-2008 | 10:29 AM
timber74wolf's Avatar
I bet it is 1 of 2 things. 1 a kill switch like everyone has mentioned. More than likely a fuelpump cut off switch. or 2 a toggle switch for fog lights. Do you have factory fog lights and a factory switch? Or do you have aftermarket fog lights? That is my best guess. Or just maybe come to think of it... Did you buy your truck 2nd hand and did it have a stereo system in it? I know my mini truck I installed a toggel switch to turn on my amp since my power antena wire was faulty. Hope this might help.
Old 07-10-2008 | 11:54 AM
knoxy's Avatar
i have the same switch for my DVD deck for bypass... it look probably for stereo system, or alarm system. typical installation bay switch!
darkyellowsky
22
03-17-2022 04:27 PM
BirdDooHead
01-27-2016 05:04 PM
hallierose
01-19-2011 09:47 AM
BirdDooHead
09-19-2008 08:48 PM
dhanus
11-04-2006 11:58 PM
Quick Reply: Mystery Switch
