Need help!!
Old 06-08-2010 | 09:31 PM
Stephen115's Avatar
Default Need help!!
I want to get 17'' offset wheels for my 05 z71, it is at stock ride height.
I want to get the look of the wheels being out past the fenders.
so, what wheels should I get and what would be the best offset to get the wheels past the fenders?
thank you
Stephen j
Old 06-08-2010 | 09:51 PM
RUFFNECK4LYFE's Avatar
Im not sure what offset but try not to use the spacers or adapters. Going out too far will stress the hub bearings.
Old 06-08-2010 | 10:22 PM
Stephen115's Avatar
ok, thank you
Old 06-09-2010 | 12:34 AM
seejgo2's Avatar
Member
also i dont know how far out ur going but you have to watch on the fronts as we did a mod to a 1 ton and the wheels naturally sit offset due to rim (off set in) but in putting a normal rim on it sat them too far out and changed the steering arch of the wheels and made them hit. we had to change the whole front hubs to 3/4 ton hubs. again not sure how far out ur going or if it will make that much of a difference but if you do add spacers watch it.
J
Old 06-09-2010 | 11:27 AM
Stephen115's Avatar
J
i dont know how far out im going either, thats why I need help
Old 06-09-2010 | 04:00 PM
chevyrules's Avatar
Default Idea
Why not go with rims that are the right offset and just go with wider tires and a small lift, so they will clear the fenders. That way there, atleast you're not changing the offset of the wheels and stressing wheel hub bearings and etc. Spend a lil bit more $$$$$ and do the job the right way. You'll be glad you did, later on down the road.
Dawe
11-29-2011 03:05 PM
joebug1956
02-18-2009 10:03 AM
Quick Reply: Need help!!
