need help with ideas on 06 silverado
Old 01-15-2008 | 12:31 AM
06silverado22s's Avatar
Default need help with ideas on 06 silverado
well i have a '06 silverado on 22's. i have already upgraded the doorhandles, head lights (halo), tail lights, exhaust, intake and i put a programmer on it. i put the max power on it.
i was wondering what else i could do to get more power out of my truck with out putting a supercharger or turbo on it. i was also wondering if there is any way to take the trackion control. i want to be able to power stall....(burn out)
Old 01-15-2008 | 01:32 AM
MrLM7's Avatar
Default RE: need help with ideas on 06 silverado
Check out the free mods...
https://www.truckforums.com/m_17037/tm.htm
You can also shave your antenna for free. That mod is floating around in here somewhere...
Old 01-15-2008 | 03:46 PM
05RST's Avatar
Headers make some good power, it really depends on how much money you want to spend on it.
Old 01-15-2008 | 04:04 PM
southcomfort09's Avatar
there's no traction control. it's your gear ratio. you're wheels are too big to turn over. i've got the same problem. the only way to fix it is to re-build your back end
Old 01-15-2008 | 04:30 PM
05RST's Avatar
It is posible that he has traction control, I beleave that was the year that they started putting TC on trucks. and if so there should be a TC botton on the left side of the dash or in middle under the radio somewhere. but then again 22s will not be that easy to burn out with if you dont have enough power or the right gears.
Old 01-15-2008 | 04:36 PM
gpet6669's Avatar
You can put a line lock on the brakes and that should do the trick to get you to burn out. That will also help with not wearing on the rear brakes so much when you do a burnout. If you are looking for more than a smoky burnout, then you need to put traction bars on the rear. Also look at a cowl hood some sort of tounneau cover and maybe an air bag kit.
Old 01-15-2008 | 06:30 PM
smoke20's Avatar
When you get the Tq management reduced you can turn em over. I have 33s with 3.42 and I spun them several times today with the cooler weather. It is amazing how much faster my truck is @ 51 degrees.
Badmothertruckyomouth
12-19-2012 03:06 AM
woodyman
10
07-19-2010 08:03 AM
red_devil92
11-23-2009 10:45 AM
78chev2bnice
10-21-2008 09:53 PM
350C1500
11-09-2007 12:38 AM
Quick Reply: need help with ideas on 06 silverado
