negative affect???
Old 11-03-2007 | 09:32 PM
taro2413's Avatar
Default negative affect???
Aight so i put on my trans dapt tbs the other night had a oppertunity to run it tonight and it made my truck run slower....Has anyone else had this happen to them?....Also that same night i descreened my MAF but if i hit the hot wires my check engine light would of came on correct?....im pretty sure i didnt hit them. But iv'e never seen this type of maf before either do your trucks have two alluminum looking posts going straight up and down with a wire connecting the two at the top and bottom half of the MAF?....just wondering cuz my impala ss looked nothing like this.
Old 11-04-2007 | 12:47 AM
stopspazinout's Avatar
Default RE: negative affect???
yea thats how it looks. did you check your throttle body cables to see if they got improperly spaced from the spacer or not?
Old 11-04-2007 | 01:10 AM
chevy112488's Avatar
id check the throttle cables i had to do a good bit of adjustment to mine the relocator wasn't quite right...
Old 11-04-2007 | 08:21 AM
smoke20's Avatar
might as well clean your MAF while your there and reset the computer.
Old 11-04-2007 | 08:29 PM
taro2413's Avatar
according to the directions that came with it on my year which is an 05 i dont need that throttle rolocator bracket...and from what i saw its an enclosed cable system on the side of the tb and it electronically controlled by the go pedal. ill look again to make sure but thats wat i believe i saw didnt look at it to much. What should i use to clean the MAF?....also took off the tbs and it is faster now without it on...weird
Old 11-04-2007 | 08:33 PM
racethisz71's Avatar
05 shouldnt have cables its all fly by wire or electronic
Old 11-04-2007 | 09:06 PM
taro2413's Avatar
Yea just checked my tb again and its all electronic no cables
Old 11-05-2007 | 08:40 AM
jcbst12's Avatar
Your sure its lined up properly? No gaps between the intake and the tbs? Is there any "lip" between the tbs and the tb? What kind of gasket did they give you?
Old 11-05-2007 | 07:19 PM
smoke20's Avatar
Any chance you got it in there backwards? I have an 05' as well and it is all electronic, no throttle cable brackets.
Old 11-05-2007 | 07:57 PM
Cracker's Avatar
Which did you get, Smooth Bore or Torque curve?
Quick Reply: negative affect???
