Newbie with a question
Old 04-04-2005 | 04:51 AM
On20z's Avatar
Default Newbie with a question
Hi i am new to the forums so here is my first post.I currently have a 2001 silverado 2wd,lowered on 20" rims.This is my show truck but i need aquestion answered before i spend the money.I see all kinds of adds for exhaust that go from the y pipe in to a single.But has anyone done a true dual exhaust,splitting the y pipe and running 2 sets of mufflers and piping or will this throw a code,mabey why i only see the single in dual out.I do have a set of aftermarket shorty headers on now with stock y and cats with a mac performance exhaust.Will the true dual add any x hp or be a lil louder.Any help will be appreciated.
Old 04-04-2005 | 03:03 PM
Patrick's Avatar
Default RE: Newbie with a question
this is illegal in most states..where do you live?
Old 04-04-2005 | 03:09 PM
On20z's Avatar
I live in upstate,NY.
Old 04-05-2005 | 12:13 PM
Patrick's Avatar
i would check with your states emission laws, in many states, adding true duals to a vehicle is illegal unless they came stock with true duals.
Old 08-12-2005 | 07:00 PM
benben84's Avatar
I've heard going with true duals on a vortec 350 is bad because it needs the backpressure from a single muffler for best performance. Is this true?
Old 08-26-2005 | 02:30 AM
radioflyer's Avatar
I have a 97 silverado with a 305 vortec. I had a true dual system put on it with 2.5” pipes, high flow cats and a pair of Flowmaster 40 series mufflers. As far as the legality, as long as you keep the sound at a reasonable level and meet emissions (by installing 2 catalytic converters) I think you’ll be okay. You only really have to worry about back pressure if you’re going to “dump” the exhaust. I recommend having side or rear exit to avoid valve warping. One thing I do recommend is having a cross pipe to balance the exhaust flow. Also keep in mind that unless you’re running a big block, having 2.5” pipe will keep the exhaust velocity high and your cylinders free of exhaust fumes.
Good Luck
MajorSilva
16
01-29-2008 10:55 AM
sams400
07-27-2007 12:31 AM
rh1978
07-18-2007 11:25 PM
Venga68
02-08-2007 01:22 PM
runamuk
06-03-2005 01:57 AM
Quick Reply: Newbie with a question
