No heat on the driver side.
Old 10-27-2007 | 04:24 PM
usbrowns's Avatar
Default No heat on the driver side.
I am unable to heat up the air on the driver side of my truck. I swapped out the electronic control with a friend and that did not resolve the issue so I beleive the problem isa bad actuator in the air flow system. I took the dash apart but could not locate the actuator. Anyone know where the actuator is located?
Old 10-27-2007 | 07:27 PM
Argon's Avatar
Default RE: No heat on the driver side.
what truck is this?...if its a gmt800 (99-06) its at the bottom of the case
Old 12-13-2007 | 04:42 PM
usbrowns's Avatar
You were right on the driver side temperature actuator was on the bottom of the A/C case. I replaced mine and all is good except my wallet. The temperature actuator cost $228.
jte52003
02-06-2012 07:42 PM
WALT258
01-21-2009 08:07 PM
majordad
11-04-2007 01:37 AM
elite130
10-18-2007 03:19 PM
hotrod04
06-11-2005 10:15 PM
