No mechanical linkage
Old 01-08-2008 | 05:06 PM
pipestone's Avatar
Default No mechanical linkage
First post here -- I own an 06 -2500HD-Std. 5 sd. 10,000 mi.
I see there is an electronically controlled linkage for foot feed.
Ever since I'v had this truck it has been very sensitive to shifting sync; clutch/shift/gas. Also sometimes,(most of the time) drive train noise accompanies.
The shifting is not like older Chev shifting, which was more smother transitioning; clutch/shift/gas. But rather an art almost.
Do you think it could be coming from not having mechanical linkage?
Has anyone else experienced this?
pipestone
Old 01-09-2008 | 06:02 AM
Argon's Avatar
Default RE: No mechanical linkage
linkages have been gone several years now with no ill effects...i dunno why people fussed so much about the system now..they work great!
Old 01-09-2008 | 10:16 AM
pipestone's Avatar
Then why is there a bunching up feel of the drive train
componets with audible sound when you go thru the gears. I have to really be in artistic form when shifting from gear to gear to make shifts without sound in the drive train.
It seems like there is a in synchonization problem between clutch engagement and throttle response in what should be a harmonious transition from shift to shift.
Are you saying others have had the same complaint or is this just characteristic to the new design?
pipestone
Old 01-09-2008 | 11:17 AM
Argon's Avatar
i've not noticed anything like that...any codes?
Old 01-09-2008 | 12:52 PM
stopspazinout's Avatar
just be glad you dont have mechanical linkages that can pop off on you going down the road. i had a 74 that would loose linkage going down the road, until i fabbed something up that wouldnt come apart on me.
Old 01-09-2008 | 01:57 PM
Argon's Avatar
its odd how some customers freaked over a non-cable...I mean,a radio does not use a cable to increase volume,yet it seems pretty reliable.
BigJesseRay
12-10-2014 10:30 PM
David S
03-06-2013 08:44 PM
superstu240
Silverado/Sierra FAQs
07-24-2011 04:11 PM
80skeys
05-31-2010 08:56 PM
Mr_Shamrock
9
07-06-2009 02:40 PM
Quick Reply: No mechanical linkage
