No power to stereo
Old 09-28-2010 | 10:39 PM
Olsy's Avatar
Default No power to stereo
just bought a 93 sierra the other day and the sony stereo isn't working, checked fuses, both seem to fine. previous owner said it worked, so im not sure where to start...any tips or advice?
Old 09-29-2010 | 08:22 AM
Did you check the fuses in the trucks fuse panel and the fuse on the radio itself? You will have to remove the radio to check it's fuse, but you can also verify that it has power and ground at the same time. With the key on you should have power to both the red and yellow wire and the black should be attached to a ground source. Good Luck!
Old 09-29-2010 | 08:47 PM
Olsy's Avatar
thanks for the reply, i checked all fuses including back of the stereo and it checked out...how do i test for power to red and yellow?
Old 09-29-2010 | 09:55 PM
You need a test light or multimeter. If you don't have one they sell cheap test lights at your local auto parts store.
Old 09-29-2010 | 10:42 PM
Olsy's Avatar
thanks for the help, i'll look into it tomorrow, i do have a multimeter kicking around so i'll try that and see what comes up...thanks again for the help
Old 09-30-2010 | 12:01 AM
RUFFNECK4LYFE's Avatar
There is also a fuse in the back of these aftermarket stereos.
JohnAdamsR
09-26-2007 10:36 PM
fixitaz
05-22-2007 03:26 AM
tyweston1
04-17-2007 12:02 AM
BigTexasChevy
35
04-09-2007 03:37 PM
WW Z71 Vortex
06-22-2006 01:34 AM
