Noisy Steering Wheel
Old 07-03-2006 | 10:13 PM
HSV Madman's Avatar
Default Noisy Steering Wheel
I have a 99 Silverado Z-71 and the steering wheel seems to need lubrication. It makes noise when I turn the wheel sharply. If I spray (WD-40) the area under the dash will this solve it longterm?
Old 07-04-2006 | 12:07 AM
DominicZ71's Avatar
Default RE: Noisy Steering Wheel
Have you tried spraying lubricant on where you think the noise might be coming from?
If so Has this helped. I usually use lithium grease on stuff.
Old 07-27-2006 | 01:40 PM
tnuts's Avatar
ORIGINAL: HSV Madman
GM has a lube kit for the steering shaft noise. Just see your dealer and they will make it just like new.
Old 07-30-2006 | 01:29 PM
Low01Silverado's Avatar
ya thats what i did (got thet lube from the dealer) it did the job
Old 07-31-2006 | 12:21 AM
HSV Madman's Avatar
How much was the lube from the dealer? Is it just lithium grease?
Old 07-31-2006 | 09:41 PM
gas guzzlin 4x4's Avatar
lithium grease cured my thumpin steering wheel
Old 08-05-2006 | 01:24 AM
skipMore's Avatar
Ditto the above.
Also, if you have any play in your column from the wheel to the dash you may need to have the adjustable steering column screws tightened. If these are loose they can cause odd noises and sometimes difficult steering and shifting.
Doggy-Dog
07-17-2011 06:55 AM
mjn030
03-19-2010 12:34 AM
bindavid
09-30-2009 10:53 PM
bristolchevy
01-01-2006 07:23 PM
outdoorxman
08-01-2005 03:17 AM
Quick Reply: Noisy Steering Wheel
