None of my gages worked
Old 01-14-2010 | 08:47 PM
chevyrules's Avatar
Default None of my gages worked
My '03 Silverado........ Went out this morning to go to work, and started it up early to let it warm up (Approx. 20 Degrees outside). Just reached inside and all one motion, started it up, rather than turning the ignition to the on position, let it run thru the cycle of checking all systems etc. About half way to work, i looked down and the speedo,tach, temp and oil pressure gages were not working. Not sure if the odometer was working or not as i did not pay attention to it. Called the dealer and said it could be a couple things but w/o doing a diagnostic ($90.00), they could not be sure what was happening. So, i got to work, turned off the truck and just for Gits and shiggles, i started it back up, by going thru the turn key to on position, let it run its course, then turned ignition to start it. Started right up, and all gages were working properly. I just got out of work, 9 hrs later, did the same routine, turn to on position, then start engine and its working fine still. Any ideas why this morning, it acted like it did? First time its done that ever since i owned the truck. I have 95,000 miles on it. Thanx for any ideas in advance, Jim
Old 01-14-2010 | 09:05 PM
RUFFNECK4LYFE's Avatar
Well that is kinda wierd. But as you know my friend, temperature affects everything!! So I would just assume that was the case and wait for a next time before spending 90 bones at the stealership for them to show you how to properly scratch your head.
Old 01-15-2010 | 05:41 PM
chevyrules's Avatar
Default Thanx
It was in the 20's this morning, and NO PROBLEM........ Can't fix it, if it ain't bruck, right?
Old 01-15-2010 | 06:37 PM
Right on!
Ricardomkz
07-17-2010 12:24 AM
dmccartyfan
11-17-2009 10:59 PM
mgcmn
03-26-2009 08:21 PM
jmerrow
05-08-2008 04:21 AM
04silgramm
11-11-2007 01:41 PM
