o/d not engaging
Old 03-05-2007 | 01:56 AM
truckman15's Avatar
Default o/d not engaging
I have a 2000 2wd, started noticing a slight lag in started from a dead stop. I soon noticed the service engine soon lamp on coupled with the o/d not engaging. What the hecks going on? [/align]
Old 03-05-2007 | 09:07 AM
Argon's Avatar
Default RE: o/d not engaging
Is it shifting at all?..Sounds like you may be taking off in 2nd and staying there..
When a gm truck has a trans fault,it "defaults" to 2nd gear.....
Old 03-05-2007 | 09:37 AM
impaladakid's Avatar
You have a 4L60E automatic. And your 1st and o/d shift solenoid has failed and needs replacing.
If you go to a big auto chain like autozone they can scan your car for codes for free.
The repair is about $500, and if youneed toask what it is, your probably not going to be able to fix it yourself.
Good luck
I can get more imfo on this topic if it will help.
Bill
Old 03-06-2007 | 12:31 AM
truckman15's Avatar
Thanks for the advise. I went to autozone this morning and bought a hayne's manual. Look at the wiring diagram as well as pulling the OBD. 1-2 shift solenoid. Might have tackled in my younger days, but after two back surgeries, better left to the pros. Put it in the shop today and was given a $200-$300 estimate. Thanks again.
PS After assessing again this morning, it was indeed starting in second and then shifting to third.
davelaclair
01-30-2015 09:52 PM
chvyfn
11-20-2010 01:49 PM
split2303
03-19-2010 04:51 PM
nibras
05-11-2008 04:00 PM
truckman15
03-09-2007 02:00 PM
