oil leak into passenger door.......
i opened the passenger door on my 1990 c1500 2wd, and there was some oil on the lower weather stripping. im not sure where it came from but there is a little oil on the frame right under the firewall. anyone have this problem before? ill look at it again tomorrow but its buggin me.
thanks
s
thanks
s
RE: oil leak into passenger door.......
Just a thought... has the truck been oil-sprayed? My truck leaks oil out the bottom of the doors and around the frame because I had it oil-sprayed. Even the dripless stuff will run a little bit.
Not trying to be smartman, just my thoughts. That is the only reason I can see for oil at the bottom of the door.
Good luck.
Good luck.
ive no clue where the oil came from. and what i saw in the engine bay was just some water. as far as i know i got some fairly clean oil in my door jam. it hasnt come back since i cleaned it.
ORIGINAL: smoke20
Maybe a dumb question, but what is oil-sprayed? Never heard of it. May just be something we don't do here.
Not too expensive... for the high quality driplees stuff it runs about $70 CAD. Or, you can set it up on four jackstands in the driveway, and shoot it with some used engine oil for free! I spend the $70, as it will save me a cab corner or fenderwell down the road. Up here, road salting is a daily thing, and you have to go the extra mile to protect your investment. Even the dealers offer an undercoating option when you buy new.
Anyways, on oil-sprayed truck is a little messy under the body and in the door and body panels, but it's better than rust!
ilmbob
01-25-2009 07:43 PM
candlman
10-05-2007 09:12 AM
mike884
Automotive Parts Wanted
01-29-2007 07:01 PM
