OK I am accepting of the brake pedal now the heat
went to church this morning in the truck. the weather was a little crisp and so I turned the temperature **** to hot. after several miles there was little heat. after many mile there was still little heat. I assume the problem to be the electronics controlling the temperature or the heater control valve itself. where would be the first place to start to diagnose and fix the problem?
RE: OK I am accepting of the brake pedal now the heat
coolant level is normal, where it should be. also the previous own disconnect the chime (because he camped a lot and want silence at night). I can't find it to hook it back up. Where is it?
the previous owner must have removed it because it isn't there. now I need to go to a salvage yard and find one. I need it because my kid will probably leave the lights on and kill the battery if not reminded.
I went over to my neighbor who has a 99 suburban and he showed me the location of the chime. mine is definitely gone. it may seem trivial to some but I want it back in but at a different tone.
Blend door is in the cab under the passenger side dash close to the center of the truck. Remove the gun box(glove box) and you should be able to see you air duct system. After that......Never had to go that far.
