ok so whats the trick to get the oil
Old 08-15-2011 | 10:26 PM
cubpak89's Avatar
Default ok so whats the trick to get the oil
ok so today after work i was tinkering with my truck found out the radiator i got for free wont work at all as the 99s dont have the heater hose on the top like the 94 does and the fitting sizes are diferent no biggy i was gonna use brass fittings to make them work
well i got all the hoses off the top then proceeded to take off the bottom got the pass side hoses off just fine
then the oil cooler outlet line snaped off on me i tried to turn it slowly then back again to kinda break it free before it broke well it broke off right at the darn fitting that goes into the radiator
so anyway i go to my auto parts store got a new radiator and oil cooler outlet hose
and spent the last 4 hours messing with the end that goes into the oil filter housing
i did move that stupid rod that goes from the trans to somewhere up on the engine i think its a support then i used a cresent to break the brass nutloose thats as far as i got before it got dark and i got mad
i know there is a clip that is sposed to come out but it wont unless i get the darn thing completley off
so what is the trick to getting it to come off its in a really wierd spot to get a line wrench on and if i turn it to much i cant get anyting on there
so any ideas ive never had this problem before today but then again i hadnt done it on a 94 ive done some on older cars and trucks
so ideas or hints or tricks needed i have to drive my moms car its a 93 buick until i get it fixed
Old 08-15-2011 | 11:13 PM
NullHead's Avatar
I can't make a mental picture of what you describe .... got any pictures of the problem fitting?
Old 08-16-2011 | 10:24 PM
cubpak89's Avatar
well i got the stuborn fitting out after another 3 hours and a pair of vice grips as thats the only thing i could use that would fit
and the rod i was talking about is the strut rod
so any way i go the new line on and the new radiator all buttoned up and tightend down suprisingly the only thing holding my radiator on is tha actual fan shroud
my oil pressure is low but thats what the gauge says not the dip stick dip stick says full
so much happier know
on to the frame work again and tearing the donor truck apart
Old 08-18-2011 | 10:20 PM
twotone's Avatar
was your oil pressure guage reading low before you changed everything out, if not make sure you have no oil leaks at the filter housing or anywhere for that, you will burn it up, the guage is for inside the block pressure, not oil level, I would double check everything.
acsudberry21
01-18-2012 11:46 AM
09GMCSierra
05-08-2011 01:44 PM
Pelicandivebomb
09-03-2009 07:18 PM
ArmyAviator
09-27-2008 04:42 PM
elite130
16
10-12-2007 07:12 AM
