Oooga Horn
Oooga Horn
Hey guys, I'm fairly bored and so I've decided to post on here about an "Oooga" Horn i recently installed on my Silverado
There wasn't much to it but the wiring was annoying as I hooked up a button (its actually pull) in my dash (on the left of the Passenger Side Airbag switch) so I had to run two wires through the firewall. I hooked it up to my battery, and the closest good ground was my negative on the battery as well.
So now I have a very clean looking pull switch in my cab, and when you pull you hear a delightfully classic "OOOOGA!"
I'll upload some pics soon!
This first pic is the button in my cab.
And these are 2 pics, one of the wiring from inside the cab through the firewall, followed by one that is the engine bay side of the firewall.
This is my wiring setup on my batter (I'm installing a fuse/fuse holder on the positive wire soon to protect from fires due to shorting)
And this is the mounting of the horn, and a little viewpoint from the grille. Yes zipties are amazing!
Lemme know what you think!
isaac_22
12-24-2007 01:33 PM
bobbie53
06-01-2007 02:25 PM
