Passenger Window quit working??
I've got an 03 Z71 and the passenger window stop working. I can't get it to work, I've tried both Window switches the one on my side and the one on the passenger door. Did the motor go out? ANyone have this issue?
RE: Passenger Window quit working??
I had this problem with my '99 Z91 on the driver side. it was the cable linkage for the window was all torn up. Unfortunately you cannot get the linkage with out the motor. I would check the parts stores before I took it to a dealer they will want over $300.00
I would start small and work your way big, make sure you have power in and out of the moter, if you have power in but not out i would say the moter is shot. if you have power in and out make sure your moter itself is functioning correctly. . .
