performance motor
Old 02-06-2008 | 11:01 PM
smoke20's Avatar
Default performance motor
No, I am not having any motor issues, just planning for the future. So, I want to plan on the right amount of money for the next motor I put in this truck and I need some input. The motor will need to be hgh output, good reliability, and last 100-200k miles or longer. Price is not a big problem as long as it is reasonable. I figure up to 5k. Now is it better to go a rebuild and a supercharger, or a RAT motor, or etc.? Any ideas on a dream motor?
Old 02-06-2008 | 11:04 PM
stopspazinout's Avatar
Default RE: performance motor
well ill tell ya my dream motors would be a supercharged 383 stoker. or a beefed up HO 502. either one would keep ya 1/4 mile ahead of competition anyways those are my dream setups and they are under 5k to.
Old 02-06-2008 | 11:10 PM
seb37's Avatar
L92 6.2L 403HP 417lb-ft of torque new crate motor $7000.00 it is standard in the 2007 Escalade and the Yukon Denali GM#19165485
Old 02-06-2008 | 11:16 PM
seb37's Avatar
Or if u really want to step it up and spend some money GM#19165058 LS7 427 505HP 470lb-ft of torque $13,000.00
Old 02-06-2008 | 11:18 PM
smoke20's Avatar
but 7k for a motor that is restricted seems a waste, the 502 seems a better way to go. I think the RAT is a 502 as well.
Old 02-06-2008 | 11:32 PM
seb37's Avatar
yeah, but these are Small blocksthat are complete that would drop right in
DamnYankee's Avatar
You're going to be STARTING at about $5,000 with those goals.
A supercharger by itself is about that much and so is a turbo, unless you go with the old STS style. That's not even including the transmission (an easy $3,000 - $4,000), a fuel system to support a super charger or similar, a built rear end (an easy $1,000) and suspension. If you go with a high performance engine, all of those other things are a must.
Your best bet may be to buy someone elses project.
Old 02-06-2008 | 11:37 PM
seb37's Avatar
Also you would get a warranty with the crate motor
Old 02-06-2008 | 11:44 PM
502 crates come with a pretty decent warranty and ive seen em under 4k.
Old 02-06-2008 | 11:50 PM
seb37's Avatar
Yeah, but more work to put in a big block and about the same HP the Ram Jet 502 is 502HP and 565lb-ft of torque at $10,000.00
Quick Reply: performance motor
