is this the pinion seal?
Old 04-24-2010 | 08:49 PM
smoke14's Avatar
Default is this the pinion seal?
hey folks
I just replaced the timming cover oil seal the rear man seal and housing seal. also did the steering shaft thing. i was installing neons last night notices a drip where the drive shaft goes into the back of the trans. is that the pinion seal? luck for me i have extended warranty. i only have 48k on it and its an 06 any ideas?
thanks
Dom
Old 04-24-2010 | 09:30 PM
xpeder's Avatar
that the transmission seal
Old 04-27-2010 | 10:05 AM
tasutt2009's Avatar
yup. trans tail shaft seal
Old 04-28-2010 | 04:30 AM
smoke14's Avatar
why are all my seals doing this? its only got 48K on it and its an 06
Old 04-29-2010 | 10:09 AM
tasutt2009's Avatar
You said you replaced the rear main seal . well you had to have removed the d-shaft and trans to accomplist that, so it would not be uncommon to create a leak at the slip yoke/output shaft seal upon reassembly.
olz442
02-20-2011 07:41 AM
BAMARAM
01-07-2010 09:47 PM
deancf
10-08-2009 06:00 PM
Jaybow
11-10-2008 06:10 PM
Randyman
04-21-2008 10:55 AM
Quick Reply: is this the pinion seal?
