Piston Slap cold start. 95 Chevy 1500
Old 08-09-2011 | 07:50 AM
JTanner27's Avatar
Default Piston Slap cold start. 95 Chevy 1500
I was reading a thread about the vortecs having a piston slapping noise on a cold start. my 95 tbi has done that after a couple months of rebuilding the motor. mechanics say it could be the torque converter, flywheel, many things. any ideas of what i can check to start eliminating causes?
Old 08-10-2011 | 01:46 AM
NullHead's Avatar
uhh ... well sounds like the sky's the limit.
I'd start with a stethoscope and listen for where the noise is the LOUDEST. You'll be able to hear the noise everywhere, but figure out where it's the loudest and go from there.
Good luck
Old 08-11-2011 | 02:42 AM
JTanner27's Avatar
that eliminates alot. not. lol but thanks for the help
Old 08-11-2011 | 08:00 AM
Check torque converter bolts, but they would make the noise all the time not just on start up. Usually you can tell when it is TC bolts by putting it in gear and the noise changes - sometimes if you power brake it (not spinning the rear the tires just giving a little gas with foot on the brake in gear) it will completely go away. Sounds like you have an oil pressure issue if the TC bolts are tight.
Old 08-11-2011 | 06:29 PM
JTanner27's Avatar
my oil pressure is usually a little lower then 40. if its normal or not im not sure. but im not losing oil as far as i know. havent noticed it anyway. what would cause the oil pressure issue? thanks for all the help.
Old 08-11-2011 | 07:40 PM
NullHead's Avatar
I'm not sure if my truck has an oil pressure issue, but in my mind, it's okay. My gauge pegs as soon as the engine runs and is cold for a bit. After running at running temperature, then the oil pressure drops to the center of the gauge and fluctuates based on RPM. It apparently has a new oil sender on it.
I'm not sure who's is correct, but it's there for discussion.
Old 08-11-2011 | 09:55 PM
MrDragon's Avatar
You could have a pump getting weak or even a clogged pickup tube. Either way, I have to agree with Shamrock that it sounds like an oil distribution issue.
Old 08-12-2011 | 12:08 AM
JTanner27's Avatar
boy oh boy. great. lol. well guys ill update when i get some cash to investigate all this. should be within a couple weeks. thanks for all the help an suggestions
andyrud
07-27-2014 10:33 PM
GMC89
09-03-2009 09:02 PM
izod
02-06-2009 02:38 PM
orion27
01-05-2007 03:08 AM
Z71Nutty
09-17-2006 11:27 PM
