pulling trouble codes
Old 07-06-2008 | 10:34 PM
1st time owner's Avatar
Default pulling trouble codes
I recently purchased a 1999 Sierra.The check engine light was on.My code reader does not function when hooked to the sixteen pin connector.Can someone tell me which of these pins are actually used for code reading.This code reader works on other vehicles so I know it's not that.Is there a fuse or circuit breaker that could be blown?Open for suggestions.Thank you
Old 08-03-2008 | 03:20 PM
gibbs05's Avatar
Default RE: pulling trouble codes
The best thing that I found for those trucks is Diablo Motorsports programmer.Its 350.00 but you can watch your engine vitals, o2 voltage and range, timing issues, mass air reading and voltage. its worth every dime to invest in one, not to mention its the only way if you plan any mods to correct the in the ecm. also with that programmer and a laptop you can write your own programs, thats how i tweak mine, and monitor vital signs. hope that helps.
maxbencher
Silverado/Sierra FAQs
08-23-2011 08:28 PM
umpalumpa1985
12-17-2010 03:49 PM
Regal105
04-30-2007 07:12 PM
gas guzzlin 4x4
01-25-2007 10:07 AM
jvaski
12-31-2006 12:31 AM
Quick Reply: pulling trouble codes
