Question for Argon
Old 07-20-2007 | 05:23 PM
gas guzzlin 4x4's Avatar
Default Question for Argon
Hey, just thought you would be the one to ask being a GM Tech.
I just bought an '07 Silverado (new body style) LT with the 4.8
Their is a red wire bundled up with tape coming out of the wire harness leading to the fuse block under the hood. This wire has a flat ring at the end of it. I haven't checked to see if the wire is live. Anyway, what is this wire for???? I have only one battery and it is located in the right rear of the engine compartment.
Even a guess would be helpful, Thanks
Old 07-20-2007 | 08:58 PM
72charger's Avatar
Default RE: Question for Argon
I bet it is for some random accessory that you don't have.
Old 07-20-2007 | 09:31 PM
Argon's Avatar
there are two wires...1 on either side of the box...1 is for trailer brakes....the other is a power scessory to the rear (like to charge a travel trailer)...they are dead until you hook em up on the aux posts in the fusebox
Old 07-21-2007 | 09:23 AM
wannarex's Avatar
ORIGINAL: Argon
Is this true for my 03 also?
Old 07-21-2007 | 03:25 PM
Argon's Avatar
It depends on if it has a trailering package or not...if your 03 does...then yes
Old 07-21-2007 | 05:11 PM
Thanks a lot for the info. I appreciate your time and expertise!
MrLM7
05-24-2008 04:28 AM
jcbst12
03-04-2008 12:19 PM
RobF1970
09-07-2007 11:23 AM
MrLM7
07-12-2007 10:50 AM
chevy1224
9
03-08-2007 08:28 PM
